Texture (New Custom Feature!)
13
  • MichaelPascoe
    MichaelPascoe Posts: 2,943 PRO
    edited August 2023
    Glad you like it B)@michael_klineIf you like, share a copy of your studio and I'll take a look to see how it could be optimized for performance.
    There are a few reasons it runs slowly:
    • Boolean operations (add, subtract, intersect) struggle when parts get cumbersome (even with optimized code)
    • Code optimization (this was one of my first feature, so it does need to be re-written)
    • Copying the code will not make it run faster (not that I'm aware of)
    RENDERCAD
  • michael_kline
    michael_kline Posts: 21 ✭✭
    I have a texture of offset diamonds that is for additional grip friction. The "add" feature doesnt work on it, i have to make a million parts and then merge them with the body. I found that mirroring the set and saying merge with all also combines all, but everything is incredibly slow. I can dm you the link if you want to take a look. also, the model prints amazing.
  • MichaelPascoe
    edited August 2023
    @michael_kline, ah, printing; good news! If you export a bunch of Onshape parts as a composite, the printer software doesn't care as long as its a single file (I think I picked that trick up from @Evan_Reese). So, you can simply composite the texture to the main body, and have a composite part side A, and a composite part side B; like this:
    I also used the quick pattern option since the texture is on the flat portion of this part. Speeds things up quite a bit.
    https://cad.onshape.com/documents/1261d9eaaf193b5f9ca95d8e/w/19aba0d466e775e605043f16/e/3f05bb4c8...
    RENDERCAD
  • ARTy
    ARTy Posts: 2
    Hi @MichaelPascoe, I was wondering if there is a way to choose several faces of a surface. I have read that it was on your to-do list, but I haven't seen yet if it was already in the script.
    Cheers,
    Aaron
  • MichaelPascoe
    @ARTy, it is in the to-do list for the re-write of this feature. Definitely functionality I would like to see in the re-write.
    RENDERCAD
  • jacek_zagaja
    jacek_zagaja Posts: 47 ✭✭
    edited September 2023
    By using texture feature can I create regular pattern like this?
    Plate 53x63cm, 10mm deep, 25mm MDF
  • jacek_zagaja
    Dear Michael,
    This is excelent help as always. I have spent an hour trying to understand all steps and reduce border to 1mm and make a proper 53x63cm but I need more time to do it right.
  • Hi @MichaelPascoe, Can Texture be used to add a rough finish (like a sandstone surface or Cura's Fuzzy surface) or could this random bumpy effect be added in the future?
  • MichaelPascoe
    @paul_everington, those are most likely too detailed of textures for Onshape to handle in the part studio. This example shows about as small as you can comfortably go. You could go smaller, but not too much smaller, but you risk timing out.
    If you are only going for appearance, Onshape's Render Studio can achieve any texture you like. Though you would need either a Pro or Enterprise account to access the beta.
    RENDERCAD
  • Dear Michael,
    I have troubles with adding texture to spheres. I'm getting the error: 'cannot compute tangent plane'. Looks like I'm missing some ground knowledge. Could you please help with it?
  • MichaelPascoe
    @roman_liubenko, this is one of the current limitations of how I wrote the original feature that should be addressed in the elusive re-write of this feature. For now, try splitting the face of the sphere very close to the top and bottom or whichever pole orientation you need, then texture the almost sphere.
    https://cad.onshape.com/documents/af22fc4ba91d14401ede7c84/w/9f75d90a49b989691beaf37b/e/24c798419348ee5a4f3b...
    RENDERCAD
  • Hey! Was there ever any luck adding the multi-face option?
  • MichaelPascoe
    edited September 2024
    @thomas_coblentz I started a re-write of the feature but haven't had time to do anything with it.
    It will most likely need to be sponsored ($) before I'll have time to re-write it the way that I have planned. That way I can incorporate it into my daily work instead of after hours. Feel free to reach out if you want to help sponsor it: DM's here work or you can contact through our website
    https://www.cadsharp.com/
    RENDERCAD
  • steven_de_smedt
    steven_de_smedt Posts: 3 ✭✭
    hello, would it be possible to have a leather texture?
  • MichaelPascoe
    edited October 2024
    @steven_de_smedt So far, even my best attempts to make leather with this feature look horrible. As the feature currently is, I'll say no, not easily anyway. Then again, maybe I have the wrong idea and need to simplify my approach. I'll give it another shot.
    RENDERCAD
  • MichaelPascoe
    edited October 2024
    Ok, @steven_de_smedt, this is about as close as I've been able to get, it should be a good example studio for you though. Here is where the custom "leather" texture part studio is stored.
    And here is the test studio using the custom leather texture:
    https://cad.onshape.com/documents/46897a2d60ade8dbb04077f3/w/23398bd91a932d1432a5d204/e/660790ee19b59a45034a4661?renderMode=0&tangentEdgeStyle=2&uiState=670d6e494a3e6151c16b0765
    RENDERCAD
  • cool
  • Thank you for your hard work @MichaelPascoe; this is really useful in the design of the product visualization.
  • I'm working texturing on a Joystick for a controller, and it's not liking it when I try to texture it. It says "Texture 1 did not regenerate properly: Cannot compute tangent plane." Any idea on what I should do? @MichaelPascoe
  • MichaelPascoe
    edited December 2024
    @luke_bacigalupi This is a known limitation of how it is currently coded. For now, you will have to split the dome's face with a very small circle at the top. This will allow the feature to calculate the tangent planes.
    If your still having issues, feel free to share the document with me and I'll take a look.
    RENDERCAD
  • Derek_Van_Allen_BD
    Derek_Van_Allen_BD Posts: 1,089 PRO
    I know this wouldn't help performance on an already performance heavy script but by switching to the full fat booleanBodies() operation on line 1493 you get sheet metal support for subtraction. This texture tool is a laser kerf bending tool in disguise.
  • EvanReese
    EvanReese Posts: 3,055 PRO
    ooh I love that use case
    It's not the smoothest workflow because nothing sheet metal ever is but I think some basic extrusions like this Instructables link would cover a lot of bases for me. https://www.instructables.com/Curved-laser-bent-wood/
    One of the photos in that link looked like the Onshape logo so I tried it since it's a default in the texture tool. No island bodies left behind either, it just worked.
  • anssi2704
    anssi2704 Posts: 2
    Hi! I was wondering if Im doing something wrong with the texture tool or does it not like curved surfaces? Im trying to make a stippled surface to get more grip. It worked well on that flat surface but it does nothing when I press OK.
  • MichaelPascoe
    Within the Configuration 1, go to the Move tab, and move the in the -z a very small amount so that the top of the texture tools are not under the surface.
    RENDERCAD
  • MichaelPascoe
    edited July 2025
    Regarding the multi face input questions:
    Until the elusive update to the Texture feature arrives, you can now use the Approximate Face feature to quickly create a single face from multiple faces.
    RENDERCAD
  • g_lewis
    g_lewis Posts: 4 PRO
    @MichaelPascoe Trying this out for the first time today. I'm struggling to get my texture to subtract from the part, but adding works just fine. Any tips?
  • g_lewis
  • MichaelPascoe
    @g_lewis try changing the pattern type to "Staggered" rather than "Staggered & Trimmed".
    Worst case, you have to create the texture as new parts then manually use the boolean feature to subtract.
    I'm in the middle of a re-write for the Texture feature that will have some major improvements. One of them being it will have the option to output the texture as a composite part, allowing you to easily do whatever you want with the grouped parts.
    RENDERCAD
