New Featurescript: PP Surface Text 2.0
13»
  • RhettRobinson
    RhettRobinson Member Posts: 229 ✭✭✭
    @dave_cowden I too have been enjoying your FS, although I have had the same issues with the cut out not working. From what I can tell in my own models, it seems that there is some sort of bug when a revolved cut is used. Is this FS something you maintain?
  • dave_cowden
    dave_cowden Member, Developers Posts: 484 ✭✭✭
    Hi, Rhett!
    Yes, some other users have reported this issue-- I think its a bug, though i'm not sure why its started all of a sudden-- it worked well for a while.
    I do maintain this, but its on a volunteer basis, so i have not been able to make time for it in a while. its on my todo list though!
  • Glenn_Babecki
    Glenn_Babecki Member Posts: 30 EDU
    Dave,
    Any progress on fixing the "cut out" feature of this script?  I'm pretty sure my configuration is not violating the parameters that are suggested in the error message.
    Thanks,
    Glenn
  • matti_suuronen
    matti_suuronen Member Posts: 19 ✭✭
    It seems like the featurescript fails with "Raised New" when the text is just a single character. With more than one character it works ok, even though the text height is fixed.
    https://cad.onshape.com/documents/c01e7b0011921340a9964040/v/c6e683dca59c63d266ea4c5c/e/5a3cce3ebef9b5f9cd0f1c43?renderMode=0&uiState=664d872bab2b1408f46b100d
  • matti_suuronen
  • sean_trainor1988
    sean_trainor1988 Member Posts: 15 ✭✭
    What is "tracking" and "kerning" doing? Is there any way to add more fonts? This was the perfect tool for me to model a replacement Caravelle Step Light cover. I just couldn't find a great matching font
  • dave_cowden
    hi @sean_trainor1988
    Unfortunately, it is not possible to install custom fonts in Onshape— that i know of. The fonts available are only those available already in Onshape.
    Kerning and Tracking related to fine-tuning spacing between letters. Oversimplifying somewhat, Tracking is the spacing between all leters, while kerning is individual spacing between each pair of letters. Tracking is a single number that will spread your letters out or squish them. Kerning, on the other hand, is a list of values, that specify/tine spacing between each individual pair of letters.
    Its very common to fine-tune kerning when you want something to look really nice— certain letter combinations dont look ideal sometimes. You can read more here:
    https://en.wikipedia.org/wiki/Kerning
    https://en.wikipedia.org/wiki/Letter_spacing
    In the example below the first couple of examples are setting ONLY tracking— see the 2nd row and third row with spacing changed.
    The last example using kerning— and is the one highlighted. Note that Kerning has to have a value for each character pair, and accomplishes squishing the C and h together, while the others are spread.
  • sean_trainor1988
    Thanks for the explanation. I could see the effect Tracking was having but couldn't see what was happening with kerning. This makes more sense now.
  • Ste_Wilson
    Ste_Wilson Member Posts: 652 EDU
    https://practicaltypography.com/
    Is good source for further reading.
  • RhettRobinson
    @dave_cowden Any chance this would be solved by updating the FeatureScript Version from 559 to 2506 (the latest)? I came across this issue again and I have also been learning some FeatureScript myself, and I thought I might be able to copy your code and make my own tweaks to it, but ran into the issue of not having the text library that is imported at the top of the code.
  • dave_cowden
    Hi @Rhett_Robinson I think its pretty reasonable to assume that an upgrade would fix it. Its fairly dated at this point!
    I keep meaning to get around to make a new version of this ,but I keep getting distracted. Let me see if I can make some time over the holidays.
  • nic_r
    nic_r Member Posts: 9
    Hi Dave,
    thanks so much for this feature-tool, made really fun and saved me a lot of time. I only have a issue with a curved text with the letter "P". It ist slightly tilt and then it looks like a bigger gap to the other letters (sorry for beeing sooo picky here ;) ). Looks like that the mid-point for this letter is different and therefore doesn´t look like correct on a arc. On some fonts it´s not visible much, but on the "Roboto Slab bold" it does for me.
    Saw also here in the comments the picture with the sign from kevin_mason558 "CANS ONLY", the space between L and Y is bigger then to the other letters. Is it dificult to fix?
    Could you maybe adapt this in a future version please?
    Thanks in advanced
    Cheers Nic
  • dave_cowden
    Hi @nic_r
    Unfortunately I can't address how certain letters look— i'm limited to what the Onshape font produce. When text is built, under the hood each letter is created separately using sketch.
    Spacing, however, is definitely fixable with the current version. Have a look at the kerning parameters— this allows you to tweak the spacing between every character individually (you must provide a kerning value between each letter, as a comma -separated list). This is very common in the typesetting space— lots of fonts commonly need tweaks between particular letter combinations to look nice.
  • ray_s994
    ray_s994 Member Posts: 2 EDU
    Hi , @dave_cowden
    Is there a way to update your FS with the latest set of Fonts provided by OnShape? I noticed the latest version of this FS has a subset of the latest OnShape font library. I'm looking for Poppins in particular but having all the latest fonts in your super useful FS would be amazing!
    Thanks in advance,
    Ray
  • dave_cowden
    @ray_s994 Oh good tip! thanks for making me aware there are more fonts, i didnt know.
    I'll try to make time to get to this. I have a huge list of changes folks have asked for— i've just not gotten to it.
    In my defense if you have what First Robotics/FRC is, its CRAZYNESS until March!
    Its taking all my free time.
    I'll try to make it happen!
  • ray_s994
    Wow, that's an awesome competition. Thanks for the consideration and good luck with the event!!! 🍀
  • nathaniel_troutman
    nathaniel_troutman Member Posts: 7
    Any chance of getting a fix for it breaking part names/ids?
  • ben_partouch
    ben_partouch Member, csevp Posts: 162 PRO
    Awesome. Thanks for sharing @dave_cowden
  • dave_cowden
    @nathaniel_troutman can you please give me a bit more info /example on your issue? I do not have time at the moment, but when i do another release i'll fix what i can.
  • qwerty_chouskie
    qwerty_chouskie Member Posts: 2 EDU
    It seems that the font list is currently very incomplete compared to that the Text tool supports, is there a chance of this getting updated soon?
  • dave_cowden
    Hi @qwerty_chouskie oh yes, i have not updated it in a while, and I should! sounds like they have released more fonts.
    Question: what does the community think about the value of these features? To be honest, the main reason I don't spend a lot of time updating them is because i have to do it for free.
  • adam_rosen549
    adam_rosen549 Member Posts: 4
    edited June 2025
    I'm pretty much a newbie, but this is exactly the feature I needed to make a gift for a wedding party. The only additional feature I was hoping to find is the addition of the other OnShape supported fonts (Orbitron to be specific…), but that doesn't seem like something users are able to update ourselves. I would be appreciative of an update that included the new fonts, but understand how labor intensive even a minor change can be.
    Edit: I should probably tag @dave_cowden so he's aware of the community (my) thoughts on this very helpful feature.
  • edward_catchpole
    edward_catchpole Member Posts: 2
    Love this feature script, I use it all the time!
    It would be amazingly useful if we could get a 4th Extrude Type that's a cross between Cut Out and Add New - I often want letters as separate objects, but embedded in the face they're generated on. This is handy when designing for 3D printing where you want to do coloured text on a surface, but to achieve a strong colour you need a bit of depth behind it to prevent bleed-through.
    Also seconding the request for the fonts to be updated - there are so many available in Sketch's text feature now!
  • dave_cowden
    edited February 27
    @edward_catchpole Thanks for the kind words on the feature. Even though I'm doing horribly at keeping these updated, I'm doing a much better job collecting feedback. I'v added another vote for updating the sketches. I'm going to get to updating this feature, i promise!
    I do not completely understand the desired functionality for Extrude type. The end result should be an object per letter, but you would like to extrude them past the bounding face by some offset amount, while keeping them all separate objects? I would like to understand completely to so that i can consider this in my next version.
  • gyrex
    gyrex Member Posts: 38 ✭✭
    Thanks @dave_cowden for a wonderful script! Just thought I'd let you know that I'm having an issue where the script appears to be removing a part of my object when I use it
    Link to project here: https://cad.onshape.com/documents/1a6889a61ec254aa9c55a761/v/315e95712de11b57f9f10917/e/61786b6acb7bc2f9d2dfd0f0?showReturnToWorkspaceLink=true
    Also, Edward's suggestion above re having a 4th option where we could have a cutout and fill would be really handy for 3D printing where you can assign a different colour to the produced text. At the moment I'm using the thicken tool but it's not very elegant and sometimes it doesn't work well.
