Black Screen when Window Maximized
jstwinkles
Member Posts: 6 ✭✭
Hi all,
I'm using Firefox 97.0.2 on Windows 10 with the latest Nvidia drivers (511.79).
Whenever my browser window is maximized (not fullscreen), the workspace background is solid black. If I change the window size to anything less than maximized, it renders just fine. This only happens on Windows 10 and not Linux. Has anyone seen this issue before? I ran the system check, and it came back fine except the GL version isn't reported for some reason. Screenshots below.
Thanks in advance!
System check
Window maximized
Window not maximized
2
I revisited this and discovered it's being caused by enabling Firefox's "privacy.resistFingerprinting" setting in about:config. Disabling that setting fixed the issue.
4
Try using a chrome based browser with no add ons. If that does not work look in you NVIDEA control panel for full screen options for the app, could be a number of things especially if you have a gsync monitor0
aden_jones said:Try using a chrome based browser with no add ons. If that does not work look in you NVIDEA control panel for full screen options for the app, could be a number of things especially if you have a gsync monitor
Thanks, but using a chrome-based browser isn't an option. Besides, I don't think it's a browser issue since it works on Linux but not Windows using Firefox on both. I don't have a G-SYNC monitor, but I did check the NVIDIA control panel, and everything is set to use the default settings. Does anyone know why Firefox wouldn't be reporting the WebGL version though? I feel like that could be indicative of the problem.
@jstwinkles I'm having the same issue. Did you ever find a solution?Additional help from my perspective. Maximized window renders white (i.e. correctly) on my 1080 p monitors that are in portrait.The window renders black on my 1440 p monitor in landscape. And it renders black once I exceed some arbitrary left to right distance. Even minimized, if I stretch the window too far left and right, the window turns black.
Sorry for the late reply, but no, I never found a solution. I can confirm that mine has the same behavior where the black screen only appears after exceeding a certain x-width of the window. The window height doesn't seem to affect it.
This is still happening and needs a fix
BUMP, this is still an issue
4 -
Props for closing the loop:)
2 -
Coming back 4 years into a bug thread with the issue identified and a fix? You dropped this, king 👑
