Black Screen when Window Maximized
jstwinklesjstwinkles Member Posts: 6 ✭✭
edited March 2022 in Community Support
Hi all,
I'm using Firefox 97.0.2 on Windows 10 with the latest Nvidia drivers (511.79).
Whenever my browser window is maximized (not fullscreen), the workspace background is solid black.  If I change the window size to anything less than maximized, it renders just fine.  This only happens on Windows 10 and not Linux.  Has anyone seen this issue before?  I ran the system check, and it came back fine except the GL version isn't reported for some reason.  Screenshots below.
Thanks in advance!
System check
Window maximized
Window not maximized
  • jstwinklesjstwinkles Member Posts: 6 ✭✭
    I revisited this and discovered it's being caused by enabling Firefox's "privacy.resistFingerprinting" setting in about:config. Disabling that setting fixed the issue.
  • aden_jonesaden_jones Member Posts: 7 PRO
    Try using a chrome based browser with no add ons. If that does not work look in you NVIDEA control panel for full screen options for the app, could be a number of things especially if you have a gsync monitor
    Thanks, but using a chrome-based browser isn't an option.  Besides, I don't think it's a browser issue since it works on Linux but not Windows using Firefox on both.  I don't have a G-SYNC monitor, but I did check the NVIDIA control panel, and everything is set to use the default settings.  Does anyone know why Firefox wouldn't be reporting the WebGL version though?  I feel like that could be indicative of the problem.
  • austin_wilkersonaustin_wilkerson Member Posts: 2
    @jstwinkles I'm having the same issue. Did you ever find a solution?
    Additional help from my perspective. Maximized window renders white (i.e. correctly) on my 1080 p monitors that are in portrait.
    The window renders black on my 1440 p monitor in landscape. And it renders black once I exceed some arbitrary left to right distance. Even minimized, if I stretch the window too far left and right, the window turns black.
    Sorry for the late reply, but no, I never found a solution.  I can confirm that mine has the same behavior where the black screen only appears after exceeding a certain x-width of the window.  The window height doesn't seem to affect it.
  • finn_testfinn_test Member Posts: 5
    This is still happening and needs a fix
  • gregory_damrongregory_damron Member Posts: 2
    BUMP, this is still an issue
  • nick_papageorge_dayjobnick_papageorge_dayjob Member, csevp Posts: 1,245 PRO
    Props for closing the loop:)
  • Derek_Van_Allen_BDDerek_Van_Allen_BD Member Posts: 1,039 PRO
    Coming back 4 years into a bug thread with the issue identified and a fix? You dropped this, king 👑
