How to make loft follow guidelines on edge?
Hi there,
I'm trying to make an F-35, but have some issues with the front portion.
I've created a loft, and added guidelines using 3D fit splines which go from vertex to vertex. However, when I add this as a guideline to the loft, it doesn't touch the curve at all!
Additionally, when I pierce the curve, and connect a vertex to it, it doesn't actually intersect with the curve.
How do I fix these issues, so that the loft follows the guideline on the edge and make the pierce actually intersect the curve.
Thanks!
    S1mon Member Posts: 4,502 PRO
    It's possible that these are just display artifacts. Try hitting shift-R to temporarily turn on high quality.
  • MDesign
    MDesign Member Posts: 1,461 PRO
    try high quality display setting.
  • MDesign
  • yanni_papadimitriou
    yanni_papadimitriou Member Posts: 6
    Thanks, that makes sense!
