How to draw/extrude a "line" arrow
jeff_mcafferjeff_mcaffer Member Posts: 107 ✭✭✭
What is the simplest way to draw a "line" arrow? One that looks like —>. With a > head rather than a triangle head. I'm doing some backlit street number shadow boxes and logically want to Extrude > Remove the numbers and arrows. See signs | question. Of course, I could laboriously sketch the full outline of the arrow but that seems like more than should be required. I've seen examples of "box and triangle" arrows. That works but is not the style we want.
In the example part studio (signs | question) I thought I'd just draw the arrow and then Extrude > Thin > Remove. Unfortunately, for some reason, if I select all three lines that make up the arrowhead, the Extrude is somehow invalid. If I break the Extrude into two then I can get something that works but either has two "tips" (if you turn on Mid plane as in Extrudes "left 1" and "left 2") or you get a well-formed arrow with the head lines too thin (see Extrudes "right 1" and "right 2"). Ideally all the lines in this example would be .5" thick. If you don't select both the stem and a head line then the extrude doesn't know that the shape should be pointy and just does a square end so doing three Extrudes doesn't help.
Naively I would have thought that arrows would be a common thing to draw…
Suggestions?
