Better Booleans
fastwayjim
Member, OS Professional, Mentor Posts: 220 PRO
I didn't see any other place to discuss this, so...
1. When a part is mirrored about one of it's faces, there should be a toggle to automatically add a Boolean Union. An example is when you model an entire half a part, then finish it with a mirror. This is a very common workflow.
2. It is impossible to "shift select" a lot of tool parts while conducting a Boolean Subtract, because once you select it, it is immediately removed from the model tree! My workaround was to trick OS in pursuing a union, so I could select everything, then toggle it to subtract.
3. Can we add functionality to conduct Boolean operations with solids and surfaces? An example would be the "cut with surface" feature in SW. Also, It would be great for this to automatically occur if the referenced sketch is an open contour!
mark
I have also used the mirror command followed by boolean command and was looking a union on the mirror command, good to know it will be added in at some stage.
