How to measure from point to cylinder axis?
pete_7
Member Posts: 3 ✭
As the title suggests, I am trying to measure from a point in an assembly to a cylinder axis, but I can't seem to do it. Even creating a drawing and attempting to add a dimension doesn't produce the correct length, since it is not projected onto the model view plane. Is there a way to do this like one would in SolidWorks?
The following suggestions, in cases where extra entities are created, would need to be applied in the Part Studio
If the former, and it's a revolve, you may be able to select the revolve axis by showing a sketch or selecting an edge.
If the former, and it's a sweep, you will be able to select the sweep path
If the former, and it's an extrude, you will have to construct a sketch on a normal plane through the centre of the circle sketch and draw the axis
If the latter, you will have to create a plane at one of the end faces of the cylinder (if it has end faces) and extract the silhouette edge, then proceed as for an extrude, above.
Neither axis creation nor temporary axis is available at present.
I have raised an improvement request for the former, which you can upvote
(do not use browser "back" button having voted, it will cancel your vote!)
