Creating a feature script to mark bends
kyle_hofer465
Member Posts: 2 ✭
Hi,
Can someone please help me create a feature script to mark bends when the part is flattened? So basically what I want to do is select the points on each end of the bend lines and have it snap a circle sketch to each point selected. Also instead of having to define the diameter of every single one of them with the dimension tool, I need the circles to be equal to each other by default and control the diameter of the circle within the feature script.
Once done, my flat pattern will have a half-moon remove extruded on each end of my bend lines, Then those will help me show where my bend lines are after the laser cut process, generating less room for error when doing the bending process.
Any help on this would be greatly appreciated!
Kind Regards,
Kyle
Kind Regards,
Kyle
https://cad.onshape.com/documents/073ee8501e1fab82fbe32b8e/w/5a9425f9ac5675c512e36202/e/158a842299199529b1bf6b22
Twitter: @BryanLAGdesign
If you can get selecting the endpoints or the lines to work, you should be able to just sketch on a face of the flat pattern (remembering that the sketch will be in the coordinates of that face with evPlane, not world coordinates), then there are two ways of cutting the flat.
The simpler way would likely be to just call `extrude` from your FeatureScript and have it handle updating the flat pattern and everything (having a look at its precondition to see what you need to provide to it for operating on the flat.)
The other way would be to look at the inner workings of extrude (calling opSMFlatOperation and whatnot) and copy that into your feature.
Also, maybe a little bit unrelated, but wouldn't having a sharp wedge-shaped cut be a bit more accurate than a circle?
I've been meaning to make a very similar feature for a while now and have been manually adding the > and < cuts to my bends to help with alignment.
Now I'd also like to make a version with a dashed thin cut extrude (for easier bending on laser cut flats). Is there a way to select the all the dashed bend lines in the flat pattern with either FS or using the new query variables? They don't even seem like sketch entities although the dashed lines can be "used" to create lines in another sketch.
Did anyone else end up making this custom feature in the past 4 years? :D Sorry for the bump, but I'm happy to pick up the ball if there isn't something already already done!
Not a solution to the exact question, but you can use a 3rd party dxf tool to change the color of the bend line, if you export from OS with the bend line. Then the vendor will treat that line as a line to etch, rather than thru cut. That is what I was doing with SendCutSend. I emailed their help how to etch the bend lines, and they had me change them to a different color (or maybe a dashed line, I forget now). Later, I got much smarter, and had them do all the cutting and bending.
Thinking back, sometimes that line would be on the wrong side of the bend, and harder to line up on the brake.
I made a feature like this last year and is up for sale on fs.place https://fs.place/Listings/DV4I2TLAR6ZU61QH37M6IZAW30VY7CJD
Its only $20, you can see a demo of it here: https://cad.onshape.com/documents/a74c45e865d1f5b41a5e6c6e/w/cb6fbcc5186057491e42639a/e/fc13fdba9d4759c7bd509f65
Thanks, Caden. Thats a cool feature and is definitely one of the sheet metal features I'd want, so I might just buy the Enterprise license and install it on our work enterprise anyway. Fs.place is also just a cool concept and I want to support it, but I have some license questions that I didn't see answers to in the about section. Since this feature has source code included, could I also look at how you made this and make my own version of a related feature? Are their restrictions on distributing such a resulting feature etc.?
The intent of including source code is that you can take the feature and transform it as needed, or learn from it and build on that knowledge.
In this case, if you wanted different shaped markers you could modify the script.
It was nice to meet you in person @Caden_Armstrong and talk about this, but I figured I'd update the rest of this thread too with my workflow in case it helps anyone else prototyping bent sheet metal parts. My local version "X Treme Bend Lines" (i.e. [XT] for use with our xTool laser cutter) helps you export a DXF to get crisp and precisely located bends.
I ended up tweaking the feature to create only sketches on the flat patten and not actually modify any sheet metal geometry. Then when you export the DXF from the flat pattern view and make sure your settings are correct (Fig. 2), you get a file ready for the laser cutter. The nice thing about this method is that is streamlines in-house prototyping while also not effecting the STEP or PDF exports that go to production suppliers— it just creates 1 sketch per bend line under that feature.
The 1mm long bend markers on each end are also inset from the outline by 0.1mm to ensure that the laser cutter cuts your bend lines first and then does the outline. I've also found that these 1mm long laser kerf width marks make for even more precise bend locators than using the > and < style cuts.
"take the feature and transform it as needed, or learn from it and build on that knowledge."Thanks, again, Caden. Highly recommend that approach and using fs.place! Building off the query logic and worldToPlane/planeToWorld syntax unblocked me after procrastinating writing this feature for years.
It's in my features backlog to expand on @Caden_Armstrong's implementation to automatically apply these bend and roll notches to parts and not have to manually select them but I haven't gotten around to it because the notation we've chosen as a company isn't quite as straightforward as grabbing a centerline since we use sheet metal convert workflows and the edges end up being tangent edges. Whole lot more query logic needs applied.
Derek Van Allen | Engineering Consultant | Meddlerif you find a way to do it fully automatically please share your findings. I think I got stuck trying to find the bend lines without selecting them. I just wasn't able to query them.
I'm glad to hear you attempted it and ran into difficulties as well. I was starting to think I was being dumb and missing something obvious. It has been awhile since I dug into it so I've got some new tricks to try after my Bip Joints explorations. Probably I could get it to work in the 3d context without needing to go to the flat view.
