How to Make Threads on a Bolt?
raven_cail
raven_cail Member Posts: 2 ✭
Hello all! I am trying to create a tensile tester that has bolt-like ends. I've found some decent tutorials on how to create a bolt itself using the helix tool and a triangle sketch to create the thread, however my issue is that I'm not sure how they size the triangle to adjust for the diameter of the thread they want. I'm wanting my thread diameter to be 12 millimeters. If anyone could explain here I would appreciate it, or alternately if you have a tutorial video that explains it well I would be grateful!
