How do you create a sphere?
Reuben_AbrahamReuben_Abraham Member Posts: 6
I have figured out a way, but I'm quite sure there's a much simpler way to do it...
Please include any videos or gifs if possible, thanks.
  • Reuben_AbrahamReuben_Abraham Member Posts: 6
    oh, yes that is way simpler. My old method was to create a semicircle, create a new plane perpendicular to it and then draw a circle, and THEN revolve. thanks for the help!
  • christian_berriganchristian_berrigan Member Posts: 1
    I created a 1.5" diameter solid cylinder, 1.5" long.  Then selected both edges and used the filet tool and set the radius to the maximum allowable value of 0.75 in.  It sure looks like a sphere, and was super simple.  All dimensions in the generated drawing indicate a 1.5" diameter sphere.
  • davin_songdavin_song Member Posts: 1 EDU
    You can create a sphere in 2 steps. Create a sketch and draw an arc or circle and then use the revolve tool.
    Here's an example: https://cad.onshape.com/documents/f46a38416ac2855162ef7bed/w/ee19045eebb62fb7898e525d/e/9060850a21912e090e6916e9
    Liar. You CAN'T REVOLVE THE EDGE.
  • wayne_sauderwayne_sauder Member, csevp Posts: 657 PRO
    @davin_song
    You can revolve an edge as a surface. You can also create an enclosed sketch and revolve as a solid.
    @davin_song
    You would have to split the circle in half to revolve the edge as a surface.
  • steve_shubinsteve_shubin Member Posts: 1,118 ✭✭✭✭
    edited September 2021
    @davin_song
    As Wayne says
    Here are 2 GIF’s
  • neil_brennanneil_brennan Member Posts: 5
    This really is why Onshape is behind the the 8-ball from the start. Even basic shapes are crazy hard to create for a beginner, with no real thought seemingly ever having been put into ease of uptake. Doing the simplest things takes hours of endless tutorials and youtube videos. And yes, I know everyone has their "one weird trick" that makes it easy to do a particular thing, but honestly would it be *that* hard to add some basic primitives? Even making a sphere means 90% of users fall into the self-intersecting shape rabbit hole, and that's their first experience of Onshape.
  • martin_kopplowmartin_kopplow Member Posts: 1,380 PRO
    I've already successfully talked another dev team into this.
    So, lets's try agian ;0) :
    • A spere can be defined by a center point and a radius. Easy.
    • A cylinder can be defined by a line and a radius. Easy.
    Why not allow the thicken tool to work on curves and points?
    • Create a sphere by thickening a point.
    • Create a cylinder by thickening a line.
    • Create a bent rod thing by thickening a curve.
    • Create a bent rod thing with straight areas and rounded ends by thickening a chain of point, line, curve, point.
    That would be very easy and also fast to edit after the fact.
    Sample: One sketch - select all - one thicken feature.
  • Matias_JohnsonMatias_Johnson Member Posts: 2
    Yeah, I get it, you have to draw a half circle, then a line under it to revolve around. Thanks!
  • rosa_baeburgrosa_baeburg Member Posts: 2
    Yeah, I'm trying to be kind with myself, but really using this tool to try to draw a half circle is like exposure therapy for learning an alien language. Hopefully they'll just bite off my egg and use my body for their hatch larvae and that would be an easier ordeal than trying to make a sphere or draw a half circle in Onshape. I got A's in calculus III, but that is not an indicator that I understand how sphere's or especially half circles are constructed in this program. And it's not just me, my friend, with 10 years experience doing injection mold design with NX, Solidworks, Catia, etc. was similarly mystified. I don't know what kind of design flow you're trying to enforce here, because I'm sure it's possible to make a DSBGA chip in 5 minutes (that's what my friend did in Solidworks, which she calls ToyCAD), but I'm looking at the last 30 minutes just trying to make a half circle. yesterday it was an hour, and a cool off walk just to make a linear array, because my sketch is 1mm x 0.8 mm in scale and the default setting for linear patterns autofills at 25mm, so there were sketch artifacts way off screen in two axes causing errors. I've never left a negative review on git.com because even Linus makes me cry, in the end I know he's brilliant, like Gandalf, but the way the design flow is constrained in Onshape makes me feel like I'm on a goblin torture rack, being water dripped. Dude, c'mon, I know there's an elegant vision by some CADmeister behind this software, but it just cannot be this hard to define a sphere. It should be Create > Sphere > and then drop the shape on the screen and then a right click shows you location {x,y,z} and diameter {d} or radius {r}. I just do not understand why everything is that hard, and yes I'm not smart enough to use your software obviously.
  • rick_randallrick_randall Member Posts: 418 ✭✭✭
    @rosa_baeburg - Your story reminds me of the trouble I had converting from 2d cad to 3d parametric cad. Everything seemed backward - and I struggled at first. Once you realize the programs work very differently (and there are reasons why they are different), you begin to understand why, It is a whole new thought process, It takes a tiny bit longer up front to sketch, but the payoff is how easy you can edit things later on (this is a real pain in 2d cad). Trust the process, some very clever people have dreamed this up, and it works great as long as you are willing to learn something new. Take the time to use the free self-paced learning courses in the learning center. And contrary to the internet, you are not going to learn this in 1 hour - it's a long term commitment, and is constantly evolving. Stay with it, and I'm sure that you will have that moment when the light-bulb goes off, and it all makes sense. Good luck
  • Derek_Van_Allen_BDDerek_Van_Allen_BD Member Posts: 928 PRO
    edited January 2025
    This thread was started in 2016 but I'm here to chime in with a 2025 answer, I use this featurescript collection of primitives for the times it's relevant in my workflows. I haven't yet developed any featurescripts referencing it but I imagine there are cases where each of these object primitives might be quicker to solve particular problems without having to get into doing the multi step process to make a sphere or cone.
    https://cad.onshape.com/documents/a81f647d405a78c5b70bdbde/v/ba543ec74eb5890fd48c41c6/e/bec98f91580bad4c70005038
  • eli_shafereli_shafer Member Posts: 2
    Thanks! This is exactly what I was looking for to create a part with multiple spheres.
  • asmi_deorasasmi_deoras Member Posts: 2
    Thank you! I've never used onshape before and I'm loving it so far. We used it a little in school for a project but now I'm doing models of my own for fun.
    What's a good youtube channel or video to explain the basics and how to develop your skills?
    The best place is the learning center found behind the gearhead icon in the top right corner of the onshape window.
  • ry_gbry_gb Member, csevp, pcbaevp Posts: 191 PRO
    edited February 13
    I know this comment is old, but this has literally been the standard way to make a sphere in every parametric CAD package I've used: Creo, SolidWorks, Onshape, Fusion, etc.
    Ramon Yip | glassboard.com
    …and if everything else fails, there is still a feature script to create a sphere. (And some more primitives like cube, torus, cone …)
  • Ste_WilsonSte_Wilson Member Posts: 614 EDU
    The only thing to sphere is sphere itself.
