Who created Spur Gear? I made it faster.
joshtargojoshtargo Member Posts: 577 EDU
Spur Gear is great, but can er very slow for large complex gears. We have been using it to make curved rack and pinion sections and it means making a gear with hundreds of teeth and then chopping it down.
Taking inspiration from Performant Part Pattern, I made the hundreds of boolean operations recursive (pattern, boolean, pattern that, boolean again, etc. so instead of 400 Booleans, there are 8.
This greatly increases performance as you can see in the image from This Doc.
