Select edge of extrude? (resolved)
laird_broadfield
Member Posts: 42 ✭✭
I'm suddenly having trouble doing something I swear I've done before: selecting edges (not the face) of an extrude.
Make a rectangle, extrude.
Now, I want to select the edges of the top, and chamfer the edges. I can't convince the UI to select individual edges, only the face.
This matters, because what I really want to do is select just three of the four edges for chamfering.
(Similarly, put a hole in it. I want to chamfer just the outer edges, not the hole. Without reordering the operations, I can't seem to do that anymore.)
Okay -- let's put it down as a mystery for now. Chrome 44.0.2403.107 m. Reload did not fix it; cache flush reload (Shift-F5) did not fix it; full reboot and re-launch did fix it.
Thanks; sorry for the non-reproducibility. If I find a recipe to reproduce, I'll open a ticket.5
@laird_broadfield - You should absolutely be able to select the edges of an extrude. What browser are you using? The first thing I'd recommend doing is a hard refresh of the page by holding Shift and clicking the reload button. If that doesn't help, can you open a ticket by using the ? -> Feedback option and share the document with Onshape support?
Abe Feldman
UX/PD/Community Support0 -
Thanks; sorry for the non-reproducibility. If I find a recipe to reproduce, I'll open a ticket.5 -
I also am not able to select teh edge of an extrude now...is there a setting I am missing or something?0
@brian_rafferty what are you trying to do? If you are trying to select an edge to fillet and it won't then please open a ticket or check your browser version. If you are in a sketch and trying to reference an edge, Onshape will only select the edges of the face you used as a sketch plane - you must add constraints manually to other edges in the model.Senior Director, Technical Services, EMEA0
Years later.. ..i just had the same issue.. though i am a beginner so at first i thought i was mistaking and spent hours looking into tutorials figuring out how to select an edge.. which i thought i could do just intuitivly yesterday…
After this post i tried firefox instead of chrome that worked like a charm..0 -
Just had the same issue, tried firefox instead of chrome and that worked now.
