Solid parts
eberhard_hofer
Member Posts: 1 EDU
Would anyone know how to make a part act like a solid? In an assembly I want the other parts to "hit" it instead of swinging through it.
Any ideas?
Any ideas?
Collision is not yet detected but you can use mate limits to achieve the desired results
https://www.youtube.com/watch?v=qO8FYWtO6SQ
Nicolas Ariza V.
Indaer -- Aircraft Lifecycle Solutions0 -
You can use limits to stop part from rotating or sliding. You will need to work out your angles/distances to simulate it hitting the part which is acting like the solid. Currently you cannot just use your existing part to set your limits, you will need to mathematically calculate the limit. Hope that helps.
@eberhard_hofer
This answer is still applicable
https://forum.onshape.com/discussion/comment/5371/#Comment_5371
In addition to using limits you can also check for some interferences (if necessary ) by placing motion in a possible collision position and using the section view tool. Red areas will show overlap. Another Fit/Form/Function check approach.
Lou Gallo
Sr. Director of Product Definition. UX and Support0
