Problem with a script that sometimes doesn't work
slomi_huta
slomi_huta Member Posts: 4
If I create a point and run the script on it it doesn't work
And it only works on a point of a 3D object.
FeatureScript 2931;
import(path : "onshape/std/common.fs", version : "2931.0");
annotation { "Feature Type Name" : "lcdhole" }
export const lcdhole = defineFeature(function(context is Context, id is Id, definition is map)
precondition
annotation { "Name" : "Face", "Filter" : EntityType.FACE, "MaxNumberOfPicks" : 1 }
definition.face is Query;
    annotation { "Name" : "Point", "Filter" : EntityType.VERTEX, "MaxNumberOfPicks" : 1 }
    definition.corner is Query;
    var plane = evPlane(context, { "face" : definition.face });
    var cornerEntity = evaluateQuery(context, definition.corner)[0];
    var pt = worldToPlane(plane, evVertexPoint(context, { "vertex" : cornerEntity }));
    var sk1 = newSketchOnPlane(context, id + "sk1", { "sketchPlane" : plane });
    skPolyline(sk1, "rectLcd", {
                "points" : [
                    vector(pt[0] + 4.7 * millimeter, pt[1] - 36 * millimeter),
                    vector(pt[0] + 76.7 * millimeter, pt[1] - 36 * millimeter),
                    vector(pt[0] + 76.7 * millimeter, pt[1] - 11 * millimeter),
                    vector(pt[0] + 4.7 * millimeter, pt[1] - 11 * millimeter),
    skSolve(sk1);
    opExtrude(context, id + "ex1", {
                "entities" : qSketchRegion(id + "sk1"),
                "direction" : -plane.normal,
                "endBound" : BoundingType.BLIND,
                "endDepth" : 5 * millimeter,
    opBoolean(context, id + "bool1", {
                "tools" : qCreatedBy(id + "ex1", EntityType.BODY),
                "targets" : qOwnerBody(definition.face),
                "operationType" : BooleanOperationType.SUBTRACTION,
  • NeilCooke
    NeilCooke Moderator, Onshape Employees Posts: 6,099 image
    Try
    var sketchPlane = evPlane(context, { "face" : definition.face });
    sketchPlane.origin = evVertexPoint(context, { "vertex" : corner });
    var sk1 = newSketchOnPlane(context, id + "sk1", { "sketchPlane" : sketchPlane });
  • slomi_huta
    precondition
        sketchPlane.origin = evVertexPoint(context, { "vertex" : definition.corner });
        var pt = worldToPlane(sketchPlane, evVertexPoint(context, { "vertex" : definition.corner }));
                    "points" : [
                        vector(pt[0] + 5 * millimeter, pt[1] - 5 * millimeter),
                        vector(pt[0] + 10 * millimeter, pt[1] - 5 * millimeter),
                        vector(pt[0] + 10 * millimeter, pt[1] - 10 * millimeter),
                        vector(pt[0] + 5 * millimeter, pt[1] - 10 * millimeter),
        skSolve(sk1);
                    "direction" : -sketchPlane.normal,
                    "endDepth" : 50 * millimeter,
    Thank you very much for the response
    I really appreciate it
    But unfortunately the problem remains.
    When I cancel the BOLEAN it performs the EXTRUDE
    But with the BOLEAN it only performs a draw
  • NeilCooke
    With the sketch plane origin set to the point, you don't need "cornerEntity" or "pt", your polyline will start at (0,0), therefore:
    "points" : [
    vector(5 , - 5) * millimeter,
    vector(10, - 5) * millimeter,
    vector(10, - 10) * millimeter,
    vector(5, - 10) * millimeter,
    vector(5, - 5) * millimeter
    (or use skRectangle)
    Not sure why the boolean fails, unless it does not intersect the solid? What is the error?
