please help! tryin to to lightening and no matter what I do it wont work
the hexagon diameter is 1.5 and spaced for a patter. the thickness of the part I'm trying to lighten is 0.25. I've tried changing the size of the hexagons as well as changing the thickness of the walls, ribs, and tool Diameter.
you may need to look at the instructions (or code) for that specific featurescript. it's not official, so most people won't understand exactly how it works.
this is the feature script that is the one that is on recommended on FRCDesign.org and the only thing that isent working for me is the hexagon pattern. when I did some other random patter it worked but it was just random lines not stable at all.
I've always used Julia's Lighten FS. If you link to your doc I could take a look later.
it wont let me insert the link as its connected to my school account. do you know of a way to bypass it?
