Derived different from original!
jeff_mcaffer
jeff_mcaffer Member Posts: 108 ✭✭✭
These two shots are section views of the same part. The first one is the original ("square light block" in this studio), the second is the exact same part Derived in another studio in the same document. How is that the "tunnel" path is different? I've not done any mods in the derived studio. How is this possible and how to I stop it? AFAICT there are no overlapping variables/config that should affect (if that's even a thing). Note that there are several other tunnels though this and other parts and they all have this problem.
  • jeff_mcaffer
    Hmm, I don't see a way to delete this question, so I'll update with the appropriate emoji 🤡
    It seems that I derived the default configuration of the part and the design is not resilient (I never use the default values) so the path is messed up.
    Never mind…
  • jeff_mcaffer
    Never mind…
  • NeilCooke
    NeilCooke Moderator, Onshape Employees Posts: 6,123 image
    No worries… a good reminder for others.
  • jnewth
    edited June 4
    Also thanks for returning to post the solution/root cause. The person who finds this in six months' time looking at the same problem will appreciate it.
  • Derek_Van_Allen_BD
    Derek_Van_Allen_BD Member Posts: 1,163 PRO
    What, you're not a fan of the time honored internet tradition of marking a request as resolved but refusing to elaborate?
  • jnewth
    @Derek_Van_Allen_BDI mean, I like it aesthetically: the cliffhanger ending, the "ah" without the "choo", Chekhov's gun languishing, forgotten on the wall. Creates tension on the paper. That's craft, man.
