Intersect Views (New Custom Feature!)
MichaelPascoe
Member Posts: 2,955 PRO
Intersect Views
https://cad.onshape.com/documents/1755463e12cab51e4a5de51f/w/07865f22b67cc44e473c99a3/e/302fb7288b77057ca30414fb
How to add a custom feature to your tool bar:
12
That's pretty cool1
What dark magic is this?Very cool
太棒了!!0
@MichaelPascoe Is there a second example of showing how this feature works? When I try the script it does not make a part.0
@bryan_lagrange
I have added a "Show behind the scenes" configuration checkbox for the example tab. This should help explain how it works.
▚▞▚▞▚▞▚▞▚1 -
That's awesome
1 -
Intersect views has been moved to this location: Intersect viewsUpdate!
This feature has been completely re-written for the Onshape live 2022 contest. Hope you enjoy the update!- Sketch views can now be pre-selected and the feature will attempt to auto sort where each face goes.
- Intersect dashed lines visually show where the part is being intersected.
- Sub features now let you create additional extrudes with depths based on your sketch views.
https://www.youtube.com/watch?v=6lo66mm_gDk
▚▞▚▞▚▞▚▞▚10 -
lord this is overpowered if you do drafting from autocad1
This update is provided by @emagdalenaC2i, thanks C2i for the update!Update!
- Keep Front reference origin.
- Hide reference lines.
- Sub feature Revolve.
- Sub feature boolean option "New".
▚▞▚▞▚▞▚▞▚4 -
I made this using your featurescript. Thanks for making it, it's really cool.
3 -
Yesss!! took 6 years but someone finally used my feature 😆
That looks awesome @Evan_Sigl, nice work!.
▚▞▚▞▚▞▚▞▚5 -
Somehow never came across this, very neat! I'll have to see if there is something I can use it for now haha
@RhettRobinson it's pretty niche, mainly good for reverse engineering old 2d shop drawings for small parts from vendors.
That said, i put a ton of work into polishing it up for the custom feature competition a while back. So it's the perfect example to feed any LLM.
▚▞▚▞▚▞▚▞▚0
