How do I make a loft that are 1 cm thick
kåre_olesen
Member Posts: 2 ✭
I am designing an adapter that transitions from a square opening to a round cylinder.
I am trying to create a loft with a 1 cm wall thickness.
I have tried creating two separate lofts one solid loft and one loft to remove the internal material but I still end up with these holes.
Has anyone run into this issue before or knows how to create this type of transition correctly?
I tried using a method similar to the one shown here:
