Angled corner profile
andrei_makarenko
andrei_makarenko Member Posts: 7 ✭
Hello, I'm trying to make a 45 degree corner profile.
The problem I'm facing is that I have to turn and rotate each side of the profile and add an extrusion at an angle and I'm not sure what's the best instrument to achieve this.
So far I did this using the draft:
but I need both profile sides to be at the angle 45 degrees as on the picture below. Any ideas?
Link to a workspace - https://cad.onshape.com/documents/3d1d595fdf85c9bd0c93d398/w/2868b2ed85b6006ff54321b1/e/86445a646710f33815d6fc15?renderMode=0&uiState=6a255c428e92ad093f7d27c7
  • kenton_persons
    kenton_persons Member Posts: 4 ✭
    Are you looking for something like this? I used a loft with some guide curves.
