An Error Occured What Do I Do
ishan_raghupathula
Member Posts: 2 ✭
Onshape encountered a problem with your last operation. If the problem persists, contact support
What do I do
Exactly what it says. Ignore it unless it persists; if it does, contact support.
First, try refreshing the page. If it is preventing you from doing what you want, you're likely asking the software to do something the system doesn't allow. Try a different workflow.
