An Error Occured What Do I Do
https://lgsstudent.onshape.com/documents/25ab9e1bfd1d8ea94aa072b2/w/c13f6737faff25de7e904ac0/e/db330be8186fcc317ae74ada
Onshape encountered a problem with your last operation. If the problem persists, contact support
What do I do
  • wayne_sauder
    wayne_sauder Member, csevp Posts: 699 PRO
    Exactly what it says. Ignore it unless it persists; if it does, contact support.
    First, try refreshing the page. If it is preventing you from doing what you want, you're likely asking the software to do something the system doesn't allow. Try a different workflow.
