Boolean oparations failed to return a valid part
anders
Member Posts: 4 ✭✭
Hi again i have a new issue i get the title error when i try to extrude the face of a part into another part to make slots in it.
The public file:
https://cad.onshape.com/documents/84af1ad065c643e68dde8958/w/dfe821d4f0d34ae59f83b4ee/e/ed4e94c7f875463d96654237
Thanks in advance
The public file:
Thanks in advance
Must be to do with the little bits around the edges.
I just tried a boolean subtract rather than an extrude using your existing shape as the tool and .01cm offset and it worked. This would be a better workflow for you. If you used an extrude with the top and bottom sections extended I'd also expect it to work.
5
5 -
The usual reason for a boolean operation to fail, as in your case, is that it creates an invalid body
Often this is due to "zero thickness geometry" and the resulting body is "non-manifold"
If you search this forum on those search terms, you will get the idea.
One more thing which you probably have worked out but others may not: if you hover the cursor over the red title and wait a moment, you will get an error message which, at least in some cases, will help with working out why the modelling engine has spat the dummy.0 -
Ah yes thank you both i think i understand the issue much better now. I thought there would be a way to remove them all at once, a much faster and cleaner way to do it
