Having trouble getting two parts to become one due to compound angles
First, the document: https://cad.onshape.com/documents/f790c4df8cc85d2b9b7c3dec/w/88b9d6ea8cf4e90bee3c2489/e/e747193ea9e06b13514b1209
I'm making a part that snaps onto an angled rod with a tray attached to it.
I made the part with a sketch in the top plane, then extruded down using the rod as the direction.
And then I made the tray on the same plane and also extruded it down.
But when I tried to merge them, turns out they don't intersect. Because the clip extrusion is angled, the bottom pulls away from the face of the tray, which is more clear if I extrude the tray to the same depth as the clip and look at it from the bottom:
So I can fudge it by making the clip longer so it extends inside the tray, but it's not a great solution and there must be a better way to get those faces to meet.
Is there a tool or a way to look at this that I'm missing here?
Hey Joe. Try extruding the face of part 2 using Up to face as the end type and the face of part 4 as the face to extrude to. - Scotty
Thanks for the suggestion, Scotty. Today I learned that you can extrude existing faces!
Sadly though, I can't select the faces that I want to extrude. Maybe because they touch at the top edge?
I can select these two faces, but I can't select the one that faces the dark blue part. Nor can I select the face on the side of the blue part that faces the gray one.
It does seem like Move Boundary would do exactly what I want, but I can't select any surfaces. I've tried two different sketches and none of my surfaces or edges are selectable.
Hey Joe. The reason that face can't be selected is because it is not planar (flat). Back in Sketch 2, the element that created that face is a curve. Changing that to a line allows the face to be selected.
The method I used to get parts 3 & 4 to mate nicely was to change the curve to a line and use Move Face to have part 4 extend into part 3. I then created a sketch on the top surface of part 3 and used the Use tool to capture the edge of part 3. The resulting sketch element was used to create a surface that was then used to Split part 4. A bit of a complicated approach. Perhaps someone can chime in with a simpler way. - Scotty
How about using Replace Face on the grey face and replacing it with the blue face?
