Lightsaber design
tarek_mustafa
Member Posts: 40 ✭✭
Hi Onshape Forum, I am planning to model a cross guard lightsaber for my sons and have difficulties with the end part (don't know how to call it) please see picture.
I thought I split the face and than extrude but that did not work. I would be very thankful for any suggestion on how to realise this shape.
Hi All, This question can be closed. I did not find a way to close the question myself. The lightsaber pencil top model is public now.
5
tarek_mustafa, I can not understand your question well , could you share your document public?0
Hallo All, I found a solution myself. I had to extrude the circle to make it a solid, after that I could apply the remove tool to create the shape I needed.
5 -
Maybe you should post it to pinshape with the new Onshape app if you have access.
