5 Minutes of onshape
traveler_hauptman
Member, OS Professional, Mentor, Developers Posts: 419 PRO
The discussion about how to show off Onshape in 5 minutes made me wonder, how much actual modeling can one do in 5 minutes? So came up with a little exercise to warm up with. The rules I started with were: 5 minutes of planning on paper then 5 minutes of modeling as fast as you can.
It turns out that I severely underestimated what I can do in 5 minutes of modeling and 15 or 30 minutes is a more reasonable length of time.
I tried to record the session but my computer ate the video file before it could save it. Next time...
Here's the result. I selected the body of a little quadcopter on my desk as the inspiration. Spent 5 minutes strategizing what sequence of features would be necessary and then started modeling.
5 minutes got me this:
At 10m I had figured out a shelling approach for this situation(I rarely use it):
At 30m I had the rough model and had reached the point I had originally thought I might be able to get to in 5:
And at 45m I had refined it be dimensionally close to the original and cleaned up the propeller guard area. It's not quite ready for injection molding but not far off either....
It was a fun exercise. I learned a bit about shells and boolean operations that I didn't know before. I'll definately be doing it a few more times.
The model is here: https://cad.onshape.com/documents/47a4d745edd94562829ebae0/w/794cc7d251cd4ce2bd4edf15
Took me a bit over an hour to get a working assembly. Now to fill out and modify (could be another 4 hours to get all detail), might make a good work lamp for the shed if I can be bothered bring it out of cad to the real world.
see:
https://cad.onshape.com/documents/bc0d6937206b43bc96521413/w/c2cbdba28478453da943efd9/e/8860a5dc03df48b9af460fea
I will cut the screen shots down next, got to go and get ready for camping tonight. Bruce.
