how can i change the height of an extrusion? - I ask because the height is not on the orig sketch
geoff_hill
Member Posts: 2 ✭
How can I change the height, width or depth of an extruded part as this is not defined in the original sketch and dimensions can only be defined in sketches and not the 3D parts?
2. In the extrude dialog, there is a depth field. Change it to the desired height.
