Cannot get the right answer in 'SKETCHING IN-CONTEXT' exercise
jeroen_ritmeijer
Member Posts: 1 ✭
Hi,
I have been going over the first few exercises, which are really useful. I totally aced the first one, but I cannot understand why the answer in the 2nd exercise is incorrect. I have followed the instructions, the resulting part looks identical to what is in the exercise, but the volume I get is 50865.381 mm3, which apparently is incorrect.
Anyone got any ideas?
To get to this exercise navigate to https://www.onshape.com/learn/introduction-to-cad#, click on 'Overview and Sketching' and navigate to the 'Sketching in Context' exercise (there doesn't appear to be a way to link to it directly)
Here's hoping that the exercise is wrong or that a recent software change has slightly skewed the answer.
Optionsnoa Onshape Employees, Developers Posts: 141Hi @jeroen_ritmeijer, I went in and tried the exercise myself and you are indeed correct. We previously had rounded the answer as 50865.32 but it is fixed and reflected correctly now. Thanks for catching this!
Noa Flaherty / Customer Success / Onshape Inc.1
When I tried reloading the browser tab (after being stuck on step 5 for some minutes without the next and previous icons appearing), I was kicked right back to the page the OP provided a link to.
I don't share the enthusiasm some have for the superb behaviour and performance of modern browsers.
Sure, this problem will undoubtedly eventually be fixed, and others take its place. It's hard to meet deadlines when key tools are so capricious and the user is forced to use "latest greatest" works-in-progress all day, every day.
I'm torn between being thankful I don't pay for Chrome, and wishing I did so I had some leverage. If Onshape ever make a dedicated browser, I hope it's not free.
I would be interested in seeing the solution to learn how some of the steps are done.
thanks, but i was interested if there was a step by step solutions for each one of the problems.
thad
I followed instructions and received the same answer as in document. But when I enter this answer into "Response" input on excercise's page 8, I get
Exercise Complete
Sorry, your answer was incorrect.
My result slightly differs from the result in the document, and entering any of them gives
"Sorry, your answer was incorrect."
I ihink developers should review the exercies and their answers.
Also, instruction on the assessment page says "Select the part in the features list." - but it's not clear, which one, because there are two new parts in excercice. Looking at the provided answers, I can suppose that actually we need to select BOTH parts. But again, there is no number that passes the excercise.
Here's my "finished" product: https://cad.onshape.com/documents/a1b51fe9535317e80f17d5be/w/b2ec37c3fe45129b9a32c39c/e/60882f48b84fa1011598be0a
I'm now having a different issue with 2.2.1. When I try the extrude, it only allows me to complete it if I create it as a new part. I note that the top section of the extrude is flat and forms a tangent with the top of the cylinder, whereas in the illustrations, it shows the top section to be curved to follow the arc of the cylinder. Surely this would require a second rotate, and adjustment of the sketch (or otherwise features more advanced and not yet covered by the videos so far). When I try to chamfer the edges of that section it won't work. Am I missing something?
It would be helpful if you posted screenshots of what you're having issues with, or posted a link to the document where you are trying to complete the exercise.
If you're asking what I think you are, the face I've identified here does not need to follow the curve of the cylindrical section:
EDIT:
Additionally, we just released new courses in our learning center that are free for all users! The instructions are much more up to date with the current feature set of Onshape, and you will probably have much better luck with those than with these older tutorials. Go check them out: https://learn.onshape.com/
