In sketches, how can I change the colour of my under-defined lines ?
john_smith077
Member Posts: 175 ✭✭✭
Hello
In my sketches, I am having trouble visually distinguishing between under-defined lines (blue) and full-defined lines (black). How can I change the colour of my under-defined stuff?
Thanks
J
viru
Member, Developers Posts: 619 ✭✭✭✭
@john_smith077 , You have to give dimension for conversion from under-defined line (Blue) to fully- defined line (Black). If you do not want to give dimension then apply fix constrain to line then it will convert into black color.
Currently in Onshape user can not change property of line. This is highly requested improvement request raised in forum. You can vote for this request.
7
But that is ridiculous. It's just not all that easy to distinguish between that fairly dark blue and actual black. Edges aren't too bad but vertices can be very difficult. I am still evaluating onshape so voting for things may (or may not!) come later.
EDIT: Btw, exactly how would I go about voting for this request?
Thanks for the feedback! Some other users were having similar troubles and had a discussion about chrome plugins that can change our site to be of higher contrast:
https://forum.onshape.com/discussion/comment/32391
Our improvement requests are located on this forum in the section marked "Improvement Requests". If you go to that section and click "New Idea", you can type in your idea and similar ideas that have already been submitted will pop up. You can either vote on one of these similar issues or if none of these describe your issue well enough, submit your own request.
I have lost many hours on this. I never been told to be colorblind, only shortsighted, but small pixels of blue next to black are impossible to catch for me. this is then really difficult to get a sketch fully defined when not checking with diagnosis tool at each step. A small line next to another, or 2 close points not coincident will be very difficult to distinguish, but make a sketch not defined, but the feature are all correct, and later on, problem will accumulate…
When using diagnosis in sketch, showing these orange would be nice
Note that you can now customize sketch line colors (and line thickness):
