Switch the "LEFT" and "RIGHT" labels on the view cube?
Josh_Bond
Josh_Bond Member Posts: 6
For things like car design, by default in onshape the right side of the car won't be called right unless the front is the back. Is there a way to swap this so the left and right is oriented to the front and back as if you are inside the car/part instead of looking at it?
  • Sunkmail
    Sunkmail Member Posts: 20 ✭✭✭
    How can we use the Named View in a drawing?
  • shashank_aarya
    shashank_aarya Member Posts: 265 ✭✭✭
    Currently named view in drawing is not available but I am sure that it could be one of the priority defined in future developments. Hope it would come earliest!
  • bradley_sauln
    bradley_sauln Moderator, Onshape Employees, Developers Posts: 373 image
    You can also use Transform > Rotate in the part studio to reorient the models so that they align with the views you want out of the view cube.
    Twitter: @bradleysauln
