Switch the "LEFT" and "RIGHT" labels on the view cube?
Josh_Bond
Member Posts: 6 ✭
For things like car design, by default in onshape the right side of the car won't be called right unless the front is the back. Is there a way to swap this so the left and right is oriented to the front and back as if you are inside the car/part instead of looking at it?
You can use "Named view option" which is available when you click on smaller cube near to view cube. It works as shown below
5 -
Found an existing improvement request for it - Needs some votes:shashank_aarya said:Currently named view in drawing is not available but I am sure that it could be one of the priority defined in future developments. Hope it would come earliest! <a href="http://forum.onshape.com/discussion/2604/drawing-view-uses-named-views" title="Link: http://forum.onshape.com/discussion/2604/drawing-view-uses-named-views">http://forum.onshape.com/discussion/2604/drawing-view-uses-named-views</a><br>
edit - Fixed link5
5 -
How can we use the Named View in a drawing?0
Currently named view in drawing is not available but I am sure that it could be one of the priority defined in future developments. Hope it would come earliest!0
You can also use Transform > Rotate in the part studio to reorient the models so that they align with the views you want out of the view cube.0
edit - Fixed link5
