Centre a rectangle within another rectangle in assembly
Hi,
Please view the attached word doc with stills of the drawing. I want to centre the "base" within the roof. ie the short side are 20mm from each other and the back where the flange is line up. Looking from underneath it is off to one side.
many thanks - new to this!
  • juan_aviles
    juan_aviles Member Posts: 78 ✭✭
    If I understand you correctly, I believe the "Center point Rectangle" command will do what you are looking for.  Add your 20mm dimensions, and extrude.  Once in an assembly, group the parts together.
    If you bring the parts into an assembly separately,  you can use mates to achieve what you want.
  • phil_smith878
    phil_smith878 Member Posts: 6
    Hi,
    thanks for responding . Not quite what I need, Imagine a hollow box and then a lid sliding over it, I need the lid to slide over the rim of the box and stop at a certain distance so one side of the box and lid line up leaving a flange of equal size on the remaining 3 sides . Tried planer mate but it keeps flipping my assembly into weird configurations....sorry new to this so finding it difficult to explain.
  • phil_smith878
    YES!thats great thank you!
