Reading in data
billy2
Member, OS Professional, Mentor, Developers, User Group Leader Posts: 2,014 PRO
ilya I took this code from your spline example
FeatureScript 293;
import(path : "onshape/std/geometry.fs", version : "293.0");
import(path : "d444c222f52a949ad0c4bad3", version : "8a1976b65c772b1fe500125a");
annotation { "Feature Type Name" : "obj import" }
export const objImport = defineFeature(function(context is Context, id is Id, definition is map)
precondition
const data = BLOB_DATA.csvData;
for (var row in data)
for (var height in row)
println('height ' ~ height);
It's not reading the data:
Here's the tab with the data and the id matches up:
Here's my data:
Not sure where BLOB_DATA comes from?
For more info on FS imports (and how to get an element id), see this post.
Kevin, I did look at that link, it's really quite simple.
Thanks,
Glad to see it working smoothly!
How do I parse an input string?
Is this it?
Will I have to write my own split() function?
Let's say I want to build a library of string parsing routines so I can include it whenever. What does this look like?
How do you use split()? It's not showing an error with the syntax checker? Is it valid or not?
As for the method itself, I think the following would do what you want:
Perhaps a better question: What format are the rows of your CSV that requires this split method? You'll probably be happiest in a world where each cell of your CSV only contains one number, or a known string. We provide stringToNumber(), and I imagine processing a cell will be much easier (and faster!) if stringToNumber() is all you need.
To take a step back: Our impression has been that string manipulation isn't that common right now, and that for the time being there are bigger fish for us to fry. If the lack of these utilities is really preventing you from getting things done, definitely let us know.
Look at the Obj spec, I'm only interested in the lines beginning with v. Then need to parse x, y, z. It won't be that bad.
Obj format:
-Is there a 3D point? I see 2D point on a sketch. Was going to create a 3d line: 1pt @ origin, the other @ scan point to show point cloud.
Hoping there's a 3D point. Why do you have a 3D circle and no 3D point? Can I define a sketch with a 3D point defined in it? a point with a 'z'?
-If I wrote many string functions in a FS tab, couldn't I import them into another FS and use them?
String manipulations, I only use a few and could knock'm out in no time. Bring in a text file and parsing it for goodness. I'll roll my own for now.
Thanks
But a split function should also work. You can import feature studios into each other and reuse functions -- for now, see https://cad.onshape.com/FsDoc/toplevel.html#imports but we're working to make this easier.
We don't have a "create a 3D circle" operation -- we have a type Circle, which represents a 3D circle just like a Vector of lengths represents a point in space. To actually create a construction point, you can currently do:
opPoint(context, id + "point1", { "point" : vector(1, 2, 3) * inch, "origin" : true });
Unfortunately we don't currently display points that are not marked as "origin" -- we're working on that bug. If you are ok with a point that you don't need to select and that is only visible while the feature is edited, you can doHope this helps.
I want to select them, so I'll use opPoint.
Once again, thanks
One thing that's clear is that I have to parse the obj file and figure out how many points there are. Converting all scanned points to OS points sends servers into a frenzy.
Seems like OS handles 1,000 points to display easily, which is good enough to see the overall scanned shape. I'll create another algorithm to rescan and refine points along a cross sectional plane. Pick a plane, then OS shows points that lie close to that plane. I like this refinement technique, at least I think I do. I'll have to write it and see if it works.
questions:
-how do I window select points and delete points?
-what does "clusterPoints (points is array, tolerance is number) returns array" do?
-how do I wrap all points into a group and perform transforms on the group vs. transforming one point at a time?
Thanks
clusterPoints does what the documentation says -- it's basically a fast and robust way of finding groups of points in a given set that are close together. One place where it's used is the hole feature so that making a hole with a vertex selected twice makes only one hole at that location (rather than causing problems).
You can pass a query for many point bodies to opTransform and they will be transformed. Again interactively working with a cloud of points is not something where everything works yet.
My goal was to create sub-clouds defined from faces to produce higher resolution point clouds. It was really easy to do.
So my scan has 59822 points which OS won't render and I don't care that it won't render.
So this is the overview of the scan which I limit to around 1000 points. It's actually 1013 points because of the round off error when calculating point density.
The scanner does a good job with up & down orientation but it doesn't position the cloud perfectly. I have no user transforms written yet so the cloud is stuck in space. I created a bisecting primary slice face that's not true to X, Y, Z planes to pick up greater handle detail. The rescan is working to 1mm of this plane and produced 225 sub-cloud points with a higher resolution than the original overscan.
Sub-slices from the primary face generated 94 points around the circumference of the cup, 27 points through the upper handle and 27 points through the lower handle.
In less than a hundred lines of featurescript code, I've created a useful tool. I'm currently using SW, converting obj files to stl, and importing into SW. Once in SW it's very difficult to use. This little scan featurescript is so much more powerful than my SW approach and far more useful for reverse engineering.
Can you share the FS?
"Holly Crap Batman"
That's such an old file. That was before we had meshes. Please use with caution, or better yet, don't use at all.
https://cad.onshape.com/documents/18339e846c8cac6d61510d3a/w/b51557f546eee2bdc8a489e9/e/ef4729a66e116f079b07f09b
