move part to x axis
sweet_goals
sweet_goals Member Posts: 2
edited July 2016 in Community Support
Hi guys,
When I extrude a part it usually will mess up the orientation with the x-axis. The problem I have is when I download it to 3d print the part will not be on the x axis to easily print. I was wondering if there was a way to move the part to the x axis before I download it?
Thanks.
  • Marc_Miller
    Marc_Miller Member Posts: 111 ✭✭✭
    A part Transform could be added at the end to rotate the part 90 degrees to give it a better orientation for 3D printing.
  • kevin_o_toole_1
    kevin_o_toole_1 Onshape Employees, Developers, HDM Posts: 565 image
    Better yet, you could try a transform by mate connectors. Place one connector where you want the XY-plane/origin of the print to be, and the other connector on the default origin.
