SLDPRT part file won't import - translation error
jr_ryan
jr_ryan Member Posts: 4
Hi, I'm very new to Onshape, but it seems like a pretty straight forward system, especially for those using solidworks. I can even see that it handles part and assembly file import/export natively, which is great. Unfortunately, every time I try to import my file, it throws an error. It first tells me there was a translation error, and then it asks if I want to retry. If I do, it will complete the action without a warning or error message, but when I check the onshape document, it's completely empty, 0kb. Any ideas?
  • adamohern
    adamohern Member, OS Professional Posts: 216 PRO
    My guess is that your top level assembly is not named the same as the zip file you're uploading. This is a silly and arbitrary aspect of the Onshape import system that no one knows about--because it's completely unintuitive, hidden, and the error message doesn't give you any hint as to the real problem.
    The problem is known, and they're working on it. In the meantime, just make sure that if the top level assembly in your SolidWorks pack and go is called "MyGreatAssembly.SLDASM" that you name the resulting zip file "MyGreatAssembly.zip"
  • jr_ryan
    Interestingly, I have just now tried again, and the exact same files that failed before, now seem to import fine?! Literally nothing has changed. Very confusing.
  • john_rousseau
    john_rousseau Member, Onshape Employees, Developers Posts: 425 image
    I also agree that the translation failure feedback needs a lot of work. We hear you and are working on improving it.
  • john_rousseau
    Hi JR. We do not allow imports of CAD files with invalid parts. That is what I am seeing in the logs for at least some of your imports. Can you please open a support ticket via the "?" menu in Onshape and go to Feedback. We would like to know about the file that you tried to import with a failure that later worked.
  • jr_ryan
    hi both, thanks for replying! I was aware of the Assembly naming issue from reading through other forum posts. Unfortunately, the issue I had was with a solidworks part, importing into a part studio, not the assembly issue. Fortunately though, it looks like both issues have been resolved with this latest update, So...  thanks onsite! Keep up the good work!
  • jr_ryan
    Will do, thanks again.
