SLDPRT part file won't import - translation error
jr_ryan
Member Posts: 4 ✭
Hi, I'm very new to Onshape, but it seems like a pretty straight forward system, especially for those using solidworks. I can even see that it handles part and assembly file import/export natively, which is great. Unfortunately, every time I try to import my file, it throws an error. It first tells me there was a translation error, and then it asks if I want to retry. If I do, it will complete the action without a warning or error message, but when I check the onshape document, it's completely empty, 0kb. Any ideas?
john_rousseau
Member, Onshape Employees, Developers Posts: 425
Sorry for the hassle. It's not your fault. There's a problem with translations in your region. We are working on this now.John Rousseau / VP, Technical Operations / Onshape Inc.5 -
john_rousseau
Hi Adam. I agree. We made a change in the release that went live yesterday that will use the assembly file found in a ZIP file, regardless of what it is named, as long as it's the only one. If there is more than one assembly file and none of them have the same name as the ZIP, we will still fail the translation.John Rousseau / VP, Technical Operations / Onshape Inc.5
The problem is known, and they're working on it. In the meantime, just make sure that if the top level assembly in your SolidWorks pack and go is called "MyGreatAssembly.SLDASM" that you name the resulting zip file "MyGreatAssembly.zip"
