Can I split a part with a sketch
Can_Tavukçuoğlu
Member Posts: 1 ✭
https://cad.onshape.com/documents/5724f811e4b09be04126348a
This my document. Im trying to use split command for Part 1 (in Part Studio 1) with help of sketch 8. But it asks for a plane as entity to split with,I cant choose the sketch 8. Is it possible to split a part with help of a sketch? Its for a school project and I can feel deadline's breath on my neck. So please help!
@Can_Tavukçuoğlu Your document is shared from link and it is view only. Can you make it to public as shown below and share the link again
Sketches can be extruded as surfaces and used as splitting entities.0
@ Can_Tavukçuoğlu, sketch can be used to split a face only , if you want to split a part or surface , you can choose plane or surface to split it .0
@ Can_Tavukçuoğlu , As AP said you can extrude the sketch8 for surface and you can split the part using that surface.
