Can I split a part with a sketch
Can_TavukçuoğluCan_Tavukçuoğlu Member Posts: 1
edited May 2016 in Community Support
https://cad.onshape.com/documents/5724f811e4b09be04126348a
This my document. Im trying to use split command for Part 1 (in Part Studio 1) with help of sketch 8. But it asks for a plane as entity to split with,I cant choose the sketch 8. Is it possible to split a part with help of a sketch? Its for a school project and I can feel deadline's breath on my neck. So please help!
    shashank_aaryashashank_aarya Member Posts: 265 ✭✭✭
    @Can_Tavukçuoğlu Your document is shared from link and it is view only. Can you make it to public as shown below and share the link again
    APAP Member Posts: 2
    Sketches can be extruded as surfaces and used as splitting entities.
    shanshanshanshan Member Posts: 147 ✭✭✭
    Can_Tavukçuoğlu, sketch can be used to split a face only , if you want to split a part or surface , you can choose plane or surface to split it .
    Narayan_KNarayan_K Member Posts: 379 ✭✭✭
    @ Can_Tavukçuoğlu , As AP said you can extrude the sketch8 for surface and you can split the part using that surface.
