Creating groups in Part Studio
bert_fourie
Member Posts: 101 PRO
Is it possible to create a group in a part studio, or alternatively use an assembly group in a part studio:
I imported a motor-gearbox model, downloaded from the website of a well known supplier, into a part studio. I really only want it to be one solid model, but as often happens with this type of model it will not boolean union all the parts into one. I would like to group all parts associated with the motor gearbox so I only deal with one entity.
Another example is a bearing downloaded from an equally well known supplier.
1
Kindly refer below steps for your requirement.
Boolean
Boolean union (merge parts)
This example starts with these parts in the graphics area (they are 8 different parts):
If part is apart from each other then Boolean will not work.
