Creating groups in Part Studio
bert_fourie
bert_fourie Member Posts: 103 PRO
Is it possible to create a group in a part studio, or alternatively use an assembly group in a part studio:
I imported a motor-gearbox model, downloaded from the website of a well known supplier, into a part studio. I really only want it to be one solid model, but as often happens with this type of model it will not boolean union all the parts into one. I would like to group all parts associated with the motor gearbox so I only deal with one entity.
Another example is a bearing downloaded from an equally well known supplier.
  • _Ðave_
    _Ðave_ Member, Developers Posts: 712 ✭✭✭✭
    You can insert the entire part studio into an assembly and then group them there.
  • bert_fourie
    I need to use the group as a group in part studio as I am using it as reference to design :
  • _Ðave_
    I'm sorry that is not possible.
  • viru
    @bert_fourie,Currently user cannot create group in part studio of Onshape. You can raise improvement request for this. If all parts acts as merging bodies then you can use work around  by performing Boolean union operation.
    Kindly refer below steps for your requirement.
    Boolean
    boolean in feature toolbar
    Boolean union (merge parts)
    This example starts with these parts in the graphics area (they are 8 different parts):
    feature ex - boolean union-1
    1. Click boolean icon.
    2. Confirm that Union is selected.
    3. Click to set the focus in the Tools field, then click all of the parts (small cylinders and larger cylinder).
      feature ex - boolean union-2
    4. Click green checkmark.
      feature ex - boolean union-final
    If part is apart from each other then Boolean will not work.
  • bert_fourie
    Actually i see there has been a similar improvement request in the past.
