How do you create a dimension relationship in Sketch
Jerome_Castaneda
Member Posts: 1 ✭
how do you create a relationship of dimension say L = 2*W where L = Length W = Width parameters.
This is a great use for Onshape's variables: https://cad.onshape.com/help/Content/variable.htm
Our variables are very powerful and I have multiple examples I can show you for various situations. I have a design where I have one variable, width, and use it to drive all the other dimensions of my part so that if I need to make an adjustment, all I have to do is change the width variable.
With good design intent variables are extremely useful.0 -
@Jerome_Castaneda, You can create relationship for dimension by using variable feature. Kindly refer below video which will be helpful in dimension creation by using variable.
