Is there a bug in sweeping closed paths?
robert_hirsch
Member Posts: 6 ✭
I seems o be having a problem making an o-ring groove for a static flat surface. I make a path in one sketch. I make the sweep geometry in another sketch. I use sweep and a bizarre result happens.
Here is the path
Here is the geometry to sweep
Here is the unexpected result
Waaaahhhhh?
Here is the path
Waaaahhhhh?
Options_Ðave_ Member, Developers Posts: 712 ✭✭✭✭Try placing the sweep geometry at the end point of a line along the path instead of the midpoint.5
It works fine even if we place section at middle and if we don't have any fillet(or arc)in sweep path. But why it is not working if we have arc or fillet.
