Is there a bug in sweeping closed paths?
robert_hirsch
Posts: 6 ✭
I seems o be having a problem making an o-ring groove for a static flat surface. I make a path in one sketch. I make the sweep geometry in another sketch. I use sweep and a bizarre result happens.
Here is the path
Here is the geometry to sweep
Here is the unexpected result
Waaaahhhhh?
Here is the path
Waaaahhhhh?
Try placing the sweep geometry at the end point of a line along the path instead of the midpoint.5
