New Featurescript: Offset Faces
We've launched a new feature to Offset selected faces. A perfect implementation is not yet possible, but this is a reasonable start.
Read about it here http://store.parametricparts.com/store/p9/PP_OFFSET_FACE
Or try it out free here: https://cad.onshape.com/documents/323312569b42b381b93ee95c/w/4feba228409d550cfecc4193/e/4f18ff5b4caf83cc9e65fee9
Known limitations:
* Offsetting can be tricky. It is not hard to create geometry that generates indeterminate geometry
* Inner loops on faces with irregular definitions ( splines ) are not currently handled correctly.
Known limitations:
Some points for consideration.
I don't like the point or cometic thread that is left after hiding, deleting or tranforming a cap screw part.
I'd like to be able to set the cap screw deeper than flush to the top face. I allway like them the sit just bellow flush.
Hard to scroll down when on a small screen, maybe more off an OS issue, not normally a but when this dialogue is fully expanded goes off the screen
I have added this one to my favourites.
Keep up the good work
Bruce
Thanks a ton for the feedback!
(1) Adding a feature to inset the screw a bit should be no problem.
(2 ) Several people have mentioned the residual cosmetic thread. Unfortunately it is an onshape limitation: since it is not a part, I cannot hide it along with the part. It is possible to hide it, but ( fairly un-intuitively) you do so by hiding the feature in the top, or, of course, simply not generating it. I have resisted creating real threads for performance reasons. Do you think I should remove the cosmetic helix completely? Or should I instead generate a real thread? Unfortunately I don't really have a good solution available with currently expose Onshape functionality.
(3) yes, on my screen ( a laptop) i cannot see the full dialog fully involved. I wanted to do solve the problem by creating sideways tabs, like Boolean does-- but this functionality is only available for Onshape internal. I tried to shorten it, but I really dont have any tools I can use to make it shorter ( besides simply removing features ). If you have ideas, let me know-- but nothing I thought of felt like it was going to work. The problem will only get worse if I add the inset option, of course.
Just so you ( and other readers ) know, here are some other things coming in the future for the screw plugin:
1. hex heads
2. add M2.5 and M3.5 for ISO
3. add ability to generate Nuts and Washers ( though I may do these in a separate feature )
4. create real threads ( some users still want this )
5. 'cheese-head' ( short ) SHCS ( DIN 7984 and ISO 14580 )
Thanks for the kind words!
Thank you.
I left the capability in because I found it useful to be able to see where the threaded part ends for longer screws.
As long as cosmetic threads are a helix, I cannot hide them with the part, due to Onshape limitations. There are only two things I can do:
(1) I can remove the option to build cosmetic threads. Now they will never be annoying. But you cannot have them if you want to see where the thread ends
(2) I can cut real threads. This will be a performance issue if you have lots of bolts. If I did this, I would add a new option under the thread type menu, 'True'.
(3) I can change the default on this option to "None". Perhaps it is not clear they are optional, and doing this would only make them show up if you want them.
These are really my only options. How should I proceed?
Possible rename 'Cosmetic' to 'Show Thread' - (Hide Threads).
Per your request, I have implemented these changes in Socket Screw Creator, version 2.0:
* renamed "Cosmetic" to "Cosmetic Threads" and "Hide Threads".
* Hide Threads is now the default
* removed extraneous point
Now the default behavior does not show any objects when you hide the generated screw, which I think was the desired intent
New version can be found here ( or by simply updating your current versions )
https://cad.onshape.com/documents/2d7e0a6b68c2039da4221ebc/w/06d0026261b3d9bb908f74a1/e/b92e2707bc8e8165e208a55e
Thanks for using Screw Creator.
Cosmetic threads will not work for a 3d printer. I have making real threads on my list-- I'll get to that soon.
