Are the parameters for the Onshape features in featurescript documented anywhere?
zack_juhasz
Member Posts: 1 ✭
I've managed to get some to work by looking through the source code and finding the parameters but it's quite a pain to have to do that. After looking through the source code for loft I still don't seem to be able to figure out what parameters it needs. This is what I see in the documentation:
The issue is as far as I can tell all complex data structures in featurescript are maps and the required definition depends on what you're trying to do, so this doesn't really tell me anything. I can find the parameters for opLoft but they are of course different than the required parameters for loft, I am looking for something like this but for features (specifically the loft feature at the moment):
All I'm trying to do for this test is take a sketch in my part studio, make a copy of it a certain distance away then loft between those two sketches. Here is my code.
I agree. The documentation could use a little more detail as to what is actually part of a features definition map. Typically, the non-op version of opFeatures (e.g. extrude vs opExtrude) take the same inputs as the opFeature. The only difference is usually the addition of inputs for a boolean operation (operationType, defaultScope, booleanScope).0
