Are the parameters for the Onshape features in featurescript documented anywhere?
I've managed to get some to work by looking through the source code and finding the parameters but it's quite a pain to have to do that. After looking through the source code for loft I still don't seem to be able to figure out what parameters it needs. This is what I see in the documentation:
The issue is as far as I can tell all complex data structures in featurescript are maps and the required definition depends on what you're trying to do, so this doesn't really tell me anything. I can find the parameters for opLoft but they are of course different than the required parameters for loft, I am looking for something like this but for features (specifically the loft feature at the moment):
All I'm trying to do for this test is take a sketch in my part studio, make a copy of it a certain distance away then loft between those two sketches. Here is my code.
  • mahir
    mahir ✭✭✭✭✭
    I agree. The documentation could use a little more detail as to what is actually part of a features definition map. Typically, the non-op version of opFeatures (e.g. extrude vs opExtrude) take the same inputs as the opFeature. The only difference is usually the addition of inputs for a boolean operation (operationType, defaultScope, booleanScope).
