Vertically Symmetric Circular Sketch Pattern
mike_aizatsky
Member Posts: 3 ✭
I need to create 5 square holes on a circular arc. They catch is the middle one has to be on the vertical axis. What is the best way to create such a construct so that I can adjust arc angle and radius later?
Optionslemon1324 Member, Developers Posts: 223 EDUHow's this?
Sketch a square, circular pattern three elements to the right. Then mirror the two off-center squares into the left side. The mirror updates as expected if you later change the radius/arc angle.
Arul Suresh
PhD, Mechanical Engineering, Stanford University0 -
Optionslemon1324 Member, Developers Posts: 223 EDUThe mirror method is robust to changing the number in the pattern, but if the number stays constant, you can also do this, which is a bit easier:
Start with a square at the left edge, remove the horizontal constraint, and constrain it to be oriented with respect to the center. Then pattern 5 elements, and constrain the midpoint of the center element to be vertical to the origin.
Arul Suresh
PhD, Mechanical Engineering, Stanford University2
https://cad.onshape.com/documents/a02b007b2f2b1f638cbf6578/w/2a8a170d43d9a83fe3aa983c/e/48908bfb5856d1ccd4834cf9
