Drawing with demons ions for machinist.
matt_jay
matt_jay Member Posts: 1
Hey all,
I've created a part I will need turned out of aluminum. Seeing how I don't have a lathe in my shop I will have to take my plans to a machine shop. Is there currently any way to export a drawing that has the measurements of everything including the lengths of extrusions. I've seen them before with other cad programs that show several views of the part with measurements of everything. I hope I've explained my question clearly.
Thanks alot
  • robert_morris
    robert_morris OS Professional, Developers Posts: 176 PRO
    You will need to create the drawing yourself first, there is no way to do it automatically.
    To create a drawing of your part, right-click on the part and select "Create drawing of ....", then select a drawing sheet format in the dialog and select the "4-Views" option. This will add a new tab to your document with the drawing in it.
    You will then need to add all the dimensions that are required by using the dimension tools.
    When you are finished, you can then print or export the drawing as a PDF (or dwg/dxf).
  • PeteYodis
    PeteYodis Moderator, Onshape Employees Posts: 594 image
    edited August 2016
    @matt_jay  I would test out the idea of sharing someone else in on your design - a vastly better experience than creating a copy of the data and emailing (in my somewhat biased opinion).  The advantages here are numerous... but one thing is that all comments from those people that are shared can be captured and used to make improvements/changes all right here in the document.  Another reason is that you can eventually turn off the share permissions for that user.  This has some advantages over the method of sending a copy of the information out and having no control over where that copied information goes from there.
