Drawing tabs apparently empty
Ferrolán
Ferrolán Member Posts: 2
This is my first intervention and I must to apologize for my poor English.
In this day an new issue has emerged in my drawing tabs. In all my documents, public or private, drawings tabs appears empty but it is false because when I print the drawings appear.
Can someone tell me how can I solve this problem?
Thanks in advance and best regards for all.
  • viru
    viru Member, Developers Posts: 619 ✭✭✭✭
    Ferrolán, Generally it is not happening. Can you please open a support ticket and give some more details to Onshape support team they definitely help you.
    If you would like help with a document or you have encountered a bug, you opt to Share the document with Onshape support by clicking the Share with Onshape support toggle button at the bottom left of the dialog. When shared, the toggle button turns blue.
    When a document is shared with Onshape support, the Share toggle button turns blue; at any time you can unshare the document with Onshape support by clicking the toggle link again.
    To open a support ticket within Onshape, click on the '?' symbol on the top right of the screen and then click on "Feedback" in the menu.
    There will be a dialog to add a message and an option to share the document with the Onshape team.
    Kindly refer below video link for more detail.
    https://www.onshape.com/videos/feedback-tool
  • viru
    edited August 2016
    Ferrolán , Can you update your google chrome up to latest version.
     May be you are getting that message because you are using older version of chrome. If you are facing same problem then kindly contact with Onshape support team they will definitely help you.
