Combining multiple FS in one
Dylan_Stewart
Member, Developers Posts: 107 PRO
Is it possible to have several different FS in one?
Meaning I would like to create an enum that will allow you to choose which FS you want to use.
I know the work around here is to just physically copy and paste and have it work that way, but I don't want that.
I would like to be able to import in to a new FS all of my different features so that I can secure my code.
example:
example:
FeatureScript 392;
import(path : "onshape/std/geometry.fs", version : "392.0");
FS1::import(path : "123123123123123", version : "321321321321");
FS2::import(path : "456456456456456", version : "654654654654");
export enum Choice
annotation {"Name" : "FS1"}
ONE,
annotation {"Name" : "FS2"}
TWO
annotation { "Feature Type Name" : "Creation Choice" }
export const myCreationChoice = defineFeature(function(context is Context, id is Id, definition is map)
precondition
annotation { "Name" : "My Enum" }
definition.myChoice is Choice;
if(definition.myChoice == Choice.ONE)
run function FS1
if(definition.myChoice == Choice.TWO)
run function FS2
});Digital Engineering
You have most of it.
If the feature function in FS1 is called firstFeature, instead of "run function FS1" you'd have FS1::firstFeature(context, id, definition);
The other part is the UI definition -- that you do have to copy/paste. And if the two features share parameter names (the map fields, not the stuff in Annotation) you'd have to do a little gymnastics because you can't have duplicate parameters in a precondition.Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc5 -
You can definitely do this. You just have to import your source FS.
export import(path : "SOURCE DOC PATH STRING", version : "SOURCE DOC VERSION STRING");
After importing your source FS, you should be able to use their exposed functions like a black box. An enum can be used to decide which inputs are shown and which functions are executed. I'm sure @dave_cowden would have more to add.
5 -
Here's a working example: https://cad.onshape.com/documents/1c3157f205e22bde71791644/w/a049c6eb165ac02f76d77538/e/326fa2b5c795f0bbcf86e54c
Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc2
5 -
@ilya_baran would the copy/paste also hold true for the export enum options I have within my other FS?
Also, I'm not %100 on the "FS1::firstFeature(context, id, definition);" part.. would that be the "myFeature" that is placed when you create a new FS?
The "const" would all have to be copy/paste as well?
@mahir so instead of my "FS1::import....." I would have to put "export FS1::import......" in it's place?
Is there a good example out there that does this?
Digital Engineering0 -
No, the enum declarations need to be reexported, not copied. Doing "export FS1::import" instead of "FS1::import" will do that.
Yes, the default function name is "myFeature".
Not sure what you mean about "const" copy/pasting, but yes, you need the boilerplate in your example above.Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc0 -
@ilya_baran forgive me for my lack of knowledge/understanding... But what would go in the "(context, id, definition)" arguments?
This is what I have so far....
This is the document that I am trying to get the 2 FS options to import in to.
https://cad.onshape.com/documents/5a4159c08aa167c04de8c637/w/c4d507ef42bda6d297b57fb9/e/1d6f216f1df1cea430821a9c
This is the document that is holding the 2 working FS.
https://cad.onshape.com/documents/df4ff84027cc7cd2dde61b6c/w/b8de7280118f711b70aee96e/e/7ea31fe7944222c6fbe064e5
@lemon1324 - I know you have some experience in this as well, would you mind shining some light on this for me?
Any questions, please ask... This is kind of an important hurdle I need to jump.
Thank you.
Ok, your function body is correct -- (context, id definition) is exactly what goes in there -- you're just forwarding the context, id, and the definition to the other feature. The problem is the enums -- you are redefining them in the outer FS, which makes them different.
Unfortunately, you can't reuse the enums within a namespace (the FS1::) and you probably don't want to reexport the original feature without a namespace. So what I'd do is the following:
Make a separate feature studio with the enum declarations. Export import it without a namespace into both other feature studios. So:
FS-enums:
export enum Choice
ONE,
TWO
FS-features:
export import ( ... FS-enums ... )
// define your two features
FS-choiceFeature:
FS1::import( ... FS-features ... )
... FS1::myTableCreator(context, id, definition); ...
Does this make sense?Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc0 -
@ilya_baran I'm trying to follow as much as possible without asking many questions, but unfortunately I am unable to follow what you are telling me to do.
Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc2 -
@ilya_baran
Should it matter that one of my FS has imported parts?
I got the desired result, but my TableCreator FS is not wanting to generate.
I can only speculate that it's because of the imported legs?Digital Engineering0 -
I think it should work with imported legs the way you're doing it. What's the error you're getting?Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc0
Sorry, you are correct @ilya_baran, I was not working in the latest version.
All is good and working!!! Thank you so much!!
